This section explains the 3 different types of location data.
Many Devices or Variables are in a particular GPS position. It can be very useful to set a fixed GPS location for a Device. Another case where location data come in handy is for moving devices (imagine a truck or a boat). Hence it might be necessary to send location data in every dot.
There are 3 different ways you can post location data to Ubidots:
- Manual
- Auto
- Specified
- Setting GPS location manually
In this case the latitude and longitude are posted in the properties attribute in the body when creating a Device or updating a Device. This is the default of each device.
To add the location manually, add the following object to the Device body:
"properties": {
"_location_type": "manual",
"_location_fixed": {
"lat": 6.2486,
"lng": 75.5742
}//POST a Device with its exact GPS coordinates
curl -X POST 'https://industrial.api.ubidots.com/api/v2.0/devices/' \
-H 'Content-Type: application/json' \
-H 'X-Auth-Token: oaXBo6ODhIjPsusNRPUGIK4d72bc73' \
-d '{
"label": "truck-1-device",
"name": "Truck 1 Device",
"description": "Moving Truck",
"isActive": true,
"properties": {
"lat": 6.2486,
"lng": 75.5742
}'- Setting GPS location automatically (Default)
When the Device location is set to auto it will search for the first Variable that has a matching label with one of the three options:
positiongpslocation
To set the location automatically add the following object to the Device body:
"properties": { "_location_type":"auto" }
Please AvoidPlease avoid having two or more Variables with the allowed names (
position,gps,location) as it might create inconsistencies.
//POST a Device with automatic GPS location
-d '{
"isActive": true,
"properties": {
}'- Setting GPS location specifically
Another option to set the GPS location of a device is setting it specifically by adding the following to the properties object of a Device:
"properties": { "_location_type":"specified", "_location_variable": <variable-label> }
The <variable_label> is the Variable that contains the GPS location, please note that it goes without the tilde ~.
Thus, the isLocationVariable key is automatically set to true inside the properties of the corresponding Variable.
Using the specified mode frees you to use any name for your Variable.
//POST a Device with specific GPS location
-d '{
"isActive": true,
"properties": {
"_location_variable":<variable-label>
